[SOLVED] Can I put a 240mm radiator but keep my third fan?
Dec 27, 2018
6
I have 3 fans in the front of my case, but want to add my 240mm AIO. Is it possible to keep my third fan with the AIO installed? Or would it interfere?
as the mod says, depends on the case,
if there is no spacing between the slot on your fan, you'll not be able to keep your 3rd fan
since both side of the radiator need more space than the 2x120mm size fan
if the 3 fans on the front for aesthetic, you should get your rad on the top is possible
