You can still do this without buying new cables.
You do only need one 8-pin for the sense. The 6-pin has no sense wires. So you plug in the first connector as an 8-pin and remove the +2 from the second connector.
Ok, I was trying to make the story shorter, but since we have the expert here, I will go with more details.
I know I can use the 6+2pin (Dual Connector) PCIe cable, one 6+2 pin for the 8pin port of the GPU, and one 6 pin(without 2 pin) for the 6pin port of the GPU.
But I just prefer to use two 6+2pin PCIe (Single Connector) cables, so the GPU will be powered from two different PCIE/CPU port from the PSU.
I know there will be no difference, but I heard that it is recommended that the GPU should be powered with two seperated cables.
This is the reason why I was thinking about using one 6 pin cable and one 8 pin cable.
Now as you said, since I can not use the 6 pin cable directly to the PSU, I am thinking about connecting the 6+2pin (Dual Connector) PCIe cable to PSU, and use one 6pin to 6pin extension cable and one 8pin to 8pin extension cable to conncect the GPU with the 6+2pin (Dual Connector) PCIe cable.
Actually, the motherboard also requires a 8+4 pin power supply, but I can not find a 4 pin connector for the CPU, so I decided just conncet 8 pin to the motherboard. I know I can just use 4pin of the 4+4 connector, but scince I will not overclock the cpu too hard, I will just use a 8pin connector.
I just really don't want to remain any pins unplugged, and I think the problem is solved now. (PSU) to ( 6+2pin dual connector PCIe cable) to (6 pin extension cable and 8 pin extension cable) to (GPU). As long as I hidden the 6+2pin dual connector PCIe cable behind the chassis, I think it will look good.
