[SOLVED] Can I use an H100X AIO Water cooler in the H510 Elite case
May 14, 2020
Hi, Im thinking of buying the H510 Elite case, but there's still one thing that I dont know for sure.
Does the H100X cooler fit in the front? And If it will get enough air to efficiently cool my i5 7600k...
(if these are dumb questions it's because im pretty new to custom pc builds sorry!)
Thanks!!
That AIO will fit into the H510 Elite case, but you will have to remove the front fans. Personally I have never been a fan of a front mounted radiator, but it does work.
