I heard of people using brake cleaner to clean their pc parts, I found a can that says it's non conductive and is not harsh in plastics, will it be OK to use?
What could go wrong with it, I've seen you tubers and other people use it with no problems, compressed air will only get the easy bits out and not the dirt that is stick in right?
Don’t always trust what you seen on YouTube in any case there are better electronics cleaning solvents that you can buy get one specifically for electronics that will leave no residue
