ARGB 3 pin 5 volt, RGB 4 pin 12 volt. (usually)Can you put an RGB pin in an ARGB header and vise versa?
Well, you can, but bad stuff would almost always happen. The standard RGB ports on motherboards are different voltages.Can you put an RGB pin in an ARGB header and vise versa?
Like connecting an ARGB CPU cooler to RGB header on the motherboard or connecting the RGB case fans to ARGB header on the motherboardCan you be more specific on the devices and motherboard?
usually no
Like connecting an ARGB CPU cooler to RGB header on the motherboard or connecting the RGB case fans to ARGB header on the motherboardWell, you can, but bad stuff would almost always happen. The standard RGB ports on motherboards are different voltages.
Specifics would be better rather than a broad theoretical.
Ah ok thanks. Are there any RGB/ARGB cable extensions available for my motherboard because my cables are too short?Smoke would ensue
Hard to say because you'll left us guessing about precisely every part in your build.Ah ok thanks. Are there any RGB/ARGB cable extensions available for my motherboard because my cables are too short?
