Can ZIF and LIF connect the same flat cable?
iceman_zen
"ZIF" stands for "Zero Insertion Force", and "LIF" stands for "Low Insertion Force". They're both talking about the same kind of ATA connector. The idea is that there's a locking mechanism that clamps down on the contacts to give a good electrical connection, but that mechanism can be released to make it easy to insert or remove the cable.
So the short answer is: yes - they both work with the same cable.
Which SSD did you replace MK1214GAH with iceman? I am planning to replace MK1214GAH in my TZ37GN with a SSD but unable to find a compatible SSD.
