Hi there!
Originally I had 2 modules of this ram module:
HyperX Fury RGB, 16GB, 3600MHz, DDR4, CL17 - HX436C17FB3A/16
Back then I was able to get to 3530MHz, but never up to 3600MHz.
Today I installed 2 extra modules of a RAM that's almost identical. The only technical difference is the CAS Latency:
Kingston Fury Beast, RGB, 16GB, 3600MHz, DDR4, CL18 - KF436C18BBA/16
Now, I'm not able to run my RAM at speeds over 3333MHz. Even if I increase the voltage to 1.35, 1.4, 3400MHz won't boot, telling me that POST failed.
My config is:
Asus TUF Gaming X570-PLUS/BR
AMD Ryzen 9 5900X
I tried to capture some of the BIOS configurations:
My config is:
AMD Ryzen 9 5900X
