[SOLVED] Cant make simple volume on USB drive
lboyer904
25
Hi, I am trying to make a simple volume on a new USB drive but when I right click the thumb drive in disk management nothing happens. It isn't greyed out or anything, it just does nothing. I also tried to make a simple volume using Command prompt but it said: "A disk specified is not dynamic. Please specify a dynamic disk and try again."
My last 3 ideas:
1; the flash drive is defective in some way....bad controller, bogus, counterfeit, bad chips, etc
2; try another formating tool. I've had a lot of weirdness trying to format flash drives in Windows. Google for another.
I am aware of about 3 others.
However, I don't think I ever had trouble if I wanted NTFS on the drive. Only if I wanted FAT32.
But try another formatter nonetheless as a last resort.
3; can you see the drive at all in Diskpart? It may be formattable there?
My last 3 ideas:
My last 3 ideas:
I used EaseUS and it is working now. Thank you
