Hello everyone...I want to take a stab at OC'g but I'm finding an anomoly with my system,
E6700
Gigabyte 965P DS3
4 gig Ram
Antec Sonata II case with stock PS and Fan...I've removed the big tube that goes to the CPU to get air to the cpu..seems useless
Using Speedfan I notice that my idle core temps are core0=42 core1=45-46 and Temp1=38 and temp2=37-38
I've run orthos for 10 minutes and notice that the vcore temps go up to around 60-62 and temp2 hovers around 57-60. I've read Tom's awesome guide to temps and it appears that my e6700 is running in the hot range. According to everything I've read this really isn't right as well as the core and cpu temp being so close in temp. I've also checked to make sure the HSF is seated correctly. Any ideas on what might be the issue? I figure maybe buying a better HSF would be a good step but I would like some info before taking it back to the dealer. Don't want to OC if the chip is failing. Thanx again for any help. Great forum.
E6700
Gigabyte 965P DS3
4 gig Ram
