[SOLVED] Case cooling options
Apr 2, 2021
6
Hey guys, I recently found that my GPU is running in high temp about (80celcius), and looking forward to replacing the pre-installation fans from darkflash and my budget is quite tight and these are the options I got atm.
case: DarkFlash J11
GPU: MSI Ventus 2070
btw I already got an ml240r on top.
  1. 4 ml120r halo, three on front and one on the rear.
  2. 2 ml120r halo on the front and an NF F12 1500 pwn on the rear.
which is considered to be better for providing better airflow to lower the temperature?
i am quite a beginner in this pc thing and if you guys got some better advice, please let me know.
i would go with either
four be quiet! Silent Wings 3 High Speed PWM 120mm
or four Noctua NF-F12 iPPC-2000 IP67
both are far superior to the Cooler Master Halo series with almost twice the airflow.
and the front panel is totally closed so there's no point in RGB fans there.
hopefully the case at least has sufficient vents around the front panel that cool air can be adequately pulled in.
yeah I would also like to get 4 Noctua fans but I really have a tight budget like 50 USD and I would like to get either both of these options
  1. a silent wings 3 for the rear and 2 ml120 halo for front
  2. 2 silent wings 3 each for the rear and front
is there any better options for a tight budget like mine. :(
