Case cooling question
Sarkus
6
I've picked up an Antec Sonata case for my new system. When complete, the system will have an A64 3200 CPU, 1 Gig PC 3200 RAM, 1 120GB 7500 RPM HDD, 1 DVD/CD Optical Drive, and a 6800 GT video card. I'm wondering if the single 120mm fan in the case will be sufficient for cooling or if I should get a second 120mm fan. The CPU will have the stock HS and Fan and will also be installed using thermal grease.
Any ideas?
Well, Sarkus, I can tell you that I not only have similar guts but the same case, and I use two case fans. Under heavy load, the mobo temp never rises above 90 degrees farenheit. The computer is mostly surrounded by cool central air, circulating about the room. I find its case cooling quite sufficient.
yep i would get another 120mm fan for good measure. it will only help reduce heat, less heat=longer life for parts
I've never had a drink that I didn't like;
Got a taste of you, threw up all night!
