Hi All. It would be greatly appreciated to have your opinion.
I have Cougar Pouritas case with 3 x120 mm Cougar vortex intake fans On front panel and 1x 120 mm fan on bottom, 3x 120 mm Cougar vortex fans on top (exhaust fans) and 1x 120 mm Exhaust fan on the back. I also have NZXT X53 AIO cooling mounted on front panel without original NZXT fans, so the only air radiator receives is pushed outside air from Vortex Case fans on front panel.
Question: system runs good, and the temps are fine. Should I additionally install original NZXT coolers in front of radiator (inside the case) for “pull” air through the radiator in addition to case fans pushing air to the rad? I feel that it is difficult for air to get though the rad, but again, the temps of CPU are good.
thank you.
thank you.
