[SOLVED] Case fans
rinden
13
Hi all, I would like to know if there is any case / chassis fan that has 3 pin and Molex connector together being sold. As I have recently purchased a chassis fan for my rear part of my case but to my dismay it is a 4pin female connector as the store which I bought does not state if the product contains both Molex and Pins cabling, which hence needing me to connect it to my motherboard whereas I would want it to connect to my PSU
Thanks!
What motherboard do you have as you can always buy a fan splitter cable and run up to 3 fans of one motherboard header....even 3 pin or 4 pin fans....I have to admit it has been a long time since I have seen a fan with a molex connector. The other option is a fan controller hub...
