Case Mod Project: Corsair c70 Vengeance
MonsterMawd
807
It's good to be BUSY and I love Sci-Fi & Military theme builds. So I was very excited to receive an inquiry from Planetside2's Creative Director Matt Higby, about doing a New Conglomerate theme case for his new PC build.
"PLanetside2" is the sequel to the landmark MMO FPS has been revealed and is bigger and better than ever. PlanetSide 2 is a massive multiplayer online first person shooter. Game play delivers truly epic combat on a scale never before seen in stunning, breathtaking detail. Battles wage with literally thousands of players aligning with one of three unique factions in intense land, air and vehicle gameplay where the fight for territory is more than a victory, its survival. The "New Conglomerate"(commonly abbreviated NC) is Matt Higby's favorite faction. The NC is one of three empires waging for control over the planet Auraxis. They are characterized by hard-hitting weapons and heavily-armored vehicles that are designed with straight lines and hard edges. Their faction colors are blue and yellow.
Matt will be utilizing Corsair's H100 CPU cooler for the best optimal cooling.
I'll be creating a front intake with LEPA Chopper Cooling fan and 120mm Overkill Fan Ring
My canvas is Corsair's new Vengeance c70. It's a rugged, military inspired design. It arrives equipped with lots of features. It includes three Corsair 120mm fans, with the option to add seven more 120mm fans. Option to mount 240 or 360 radiator in the top panel. It has eight expansion slots. The retail price is $139.99. You can read my Corsair c70 Vengeance Case Review
we took time out to create c70 replacement windows here, http://www.mnpctech.com/Corsair_c70_vengeance_clear_window_replacement.html
Factory Specification List:
Warranty: Two years
Dimension: 19.7" x 9.1" x 21" / 501mm (H) x 232mm (W) x 533mm (L)
MB Support: ATX, mATX
Expansion Slots: 8
Material: Steel
Drive Bays: Three (3x) 5.25” bays, and Six (6x) 3.5”/2.5” hard drive bays
Cooling Fans Included: Three (3x) 120mm fans
Front I/O: (x2) USB 3.0, (x1) Headphone, (x1) MIC, Power, Reset Switches
Power Supply: ATX (not included)
Onto the first Case Mod!
The first modification is converting the c70's factory window to plain window without any fan hole perforations.
The c70 window assembly dismantled. Save the 16x Black screws! We will be using them to re-install out custom window.
The new window will be cut from 24" x 24" sheet of 1/8" thick, Clear, cast acrylic. I'm tracing the factory window dimensions onto the sheet.
I'm using airbrush to add weathered effects on the top H100 radiator grill with Iwata HP-CH airbrush gun with Black Enamel paint.
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9f.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9g.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9h.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9i.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9m.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9j.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9k.jpg
Bare exposed steel effect added...
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint9h_240_radiator_grill9l.jpg
Next I'll be adding more airbrushed weathered effects to the exterior of the case, including bullet holes
I'm imagining this Planetside 2 New Conglomerate case will see a lot of action in the Battlefield, so I've created some bullet holes, for the past year I've been mentored by our painter Brad in "The ways of the airbrush"...I've done bullets with templates in the past, but this time I went freehand with Iwata HP-CH airbrush gun, using Silver and Black Enamel paint.
There is a lot of different DIY techniques for creating bullet holes with an airbrush, you can use templates that you make make yourself with construction paper...don't waste your money on retail templates...
Don Johnson has a decent video tutorial to creating bullet holes on YouTube
and another DIY airbrushing guide to creating bullet holes
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint_bullet1.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint_bullet2.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint_bullet3.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint_bullet1a.jpg
planetside2_corsair_c70_case_mod_gaming_pc_higby_fan_grill_mnpctech_custom_paint_bullet4.jpg
I can't leave the ASUS Blu-Ray drive face stock! Esp after defacing and distressing everything else....lol. ...My video tutorial shares all of the steps in painting your Optical drive face, you can apply these same steps in painting any plastics..
Following the DIY steps in the link I shared above, I painted the drive face the Metallic Blue I applied to the exterior and interior of the case.
I applied 1/4" Auto Body Masking Tape, side by side, only cause it was only thin tape I had on hand... in diagonal pattern after the Metallic Blue Lacquer paint had cured for 1 hour...
I applied Matte Black Lacquer paint....
After 30 minutes, I removed the 1/4" masking tape..
Lacquer paint cures pretty fast... 30 minutes later I covered the Matte Black with same tape again.
Next, I applied combination very light coats of Gloss Orange and Metallic Gold paint
After 15 minutes, I used a wire brush to create scratches to simulate heavy usage of time...
Using Red / Maroon Scotchbrite Pad to smooth and mute down the scratches
Ready to re-install!
Final product looks great. I am curious as to why you decided to do the stripes on the cd drive an orange rather than the same yellow that is prevalent throughout the build. Regardless though is looks great. Keep up the good work. I look forward to seeing more stuff from you! :)
I used some of your suggestions when replacing the window on my C70. I really appreciate the help. Your case looks great by the way! Mine is a little less fancy but that's my style. Thanks again!
