I was thinking of buying a case with 120mm fans but would like to know if they are too loud? Also, are case cpu heat pipes really worth the extra cost? Let's hear some pro's-n-con's.
Most decent cases with 120mm fans have 3 speed selection anyway.
Decent 120mm fans are almost always quieter at the same CFM (Cubic Feet per Minute) airflow rating.
There are some dodgy ones out there though, which might be louder and be of low (under 80,000 MTBF) quality.
http://www.kustompcs.co.uk/acatalog/info_2530.htmlSpeed: 1500 RPM
Air Flow: 64 CFM
Noise Level: 14 dBA
Rotation speed 1000 RPM
Acoustic noise 22.8 dB(A)
Airflow 36.87CFM
http://www.kustompcs.co.uk/acatalog/info_2530.htmlYou don't have to buy a fan controller, you can just re wire your fan to run at 5 or 7 volts. Instructions: http://www.ramsinks.com/7vmod.asp
Also has anyone tried or seen a review of the SilenX iXtrema Pro fans? Their specs look way to good to be true (you know the saying, if it looks to good to be true, it proberbly is 😉 ).
They quote these specs for the 120MM fan:
Speed: 1500 RPM
Air Flow: 64 CFM
Noise Level: 14 dBA
I dont know which fans Lian Li use in their cases, but when I recently installed a new motherboard in one of their cases (model number pc7 plus) the fans were inaudible to my untrained ear.
