CD player problem, HELP!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Doesn't anybody have any suggestions?
My CD player/burner has stopped working.
When I put a CD in the mouse pointer changes to a CD for a few seconds than
back to the regular pointer.
When I go and view the contents on the CD in Explorer there is nothing there
(no files). I have tied many different CD's (data, music & games) all with
the same results.
I have uninstalled and reinstalled the drivers for the CD player, no help.
I purchased a new CD player/burner and have the same results.
I think all my problems started back when I updated Media Player.
Any suggestions or help would be appreciated.
P.
Just a thought.... have you enabled Auto Start on the drive? What are the
other settings when you click hardware? Best of luck to you
Ron J
> the same results.
> P.
I think auto start was enabled, but I can't find the settings. Where would I
check?
Under the Hardware tab (properties) there are four other tabs: General,
Properties, Volumes and Details.
In the General tab, it states that the drive is enabled and working
properly.
Where else could I look?
Thanks for the reply.
Pete
"Ron J" <RonJ@discussions.microsoft.com> wrote in message
news:49B29C18-4561-47E4-906F-BA5C9349367B@microsoft.com...
> the
> Ron J
>> than
>> there
>> with
>> the same results.
>> help.
>> P.
Hey Pete,
Sorry it took so long to post back. I just got in.
Ok, To check if Auto Start is on =Start>My computer>
Choose CD drive>click on Auto Play, 2nd choice on right in XP Pro> Click on
the drop down folder and make your choice> Under Actions click Select Action
To perform> you will see a choice depending on your fav. player etc, I use
windows 10 works well and no troubles with it. > If you plan on using the CD
drive the same way much of the time, I would leave the Prompt me each time
option off, it can get to be a real pain> The hardware tab has a trouble
shoot option that I find pretty good and you can also check your drivers> If
you want this drive to record> click on Recordings> click enable CD recording
on this drive> click the drop down window arrow> chose a drive for windows to
store an image of the CD to> click the second drop down arrow> chose the
best speed for your drive > tip: fastest is not always bestest > I prefer to
click on the Auto eject afer writing, that is up to you> click apply> click
Ok > cross fingers and put a CD in drive.! If it does not start> double
click on Auto Start> sometimes I have to jump start my drive but after that
it runs well for some time. I hope this was the info you were looking for
Pete. Best of luck to you.
Ron J
> check?
> properly.
> Pete
> > the
> > Ron J
> >> than
> >> there
> >> with
> >> the same results.
> >> help.
> >> P.
Ron,
Thanks for all the advice.
I tried everything you suggested and still the system will not recognize
anything in the CD player.
I even rebooted a couple of times after making changes.
I think I'm going to have to clear the hard drive and reload XP Home.
It was my last resort, but I guess that's what I will need to do.
Thanks again for your help,
Pete
news:EDD324C5-68F1-4ACD-B2C9-B3A6EC4DFA03@microsoft.com...
> Hey Pete,
> on
> Action
> use
> CD
> If
> recording
> to
> to
> click
> that
> for
> Ron J
>> would I
>> check?
>> properly.
>> Pete
>> > are
>> > the
>> > Ron J
>> >> than
>> >> there
>> >> with
>> >> the same results.
>> >> help.
>> >> P.
Don't be so drastic.
First, remove the player from the system first via Device manager, buy or
borrow a couple of replacement leads, the let XP find the drive again.
johnf
> Ron,
> Pete
>> Hey Pete,
>> Click on
>> Action
>> use
>> the CD
>> time option off, it can get to be a real pain> The hardware tab has a
>> trouble shoot option that I find pretty good and you can also check
>> your drivers> If
>> recording
>> windows to
>> the best speed for your drive > tip: fastest is not always bestest > I
>> prefer to
>> click
>> double click on Auto Start> sometimes I have to jump start my drive
>> but after that
>> looking for
>> Ron J
>>> would I
>>> check?
>>> General, Properties, Volumes and Details.
>>> properly.
>>> Pete
>>> > are
>>> > the
>>> > Ron J
>>> >> seconds than
>>> >> nothing there
>>> >> all with
>>> >> the same results.
>>> >> no help.
>>> >> P.
I will give this a try John but first I will need a little more info. (I'm
not too technically orientated),
I can uninstall the player with device manager (no problem),
can you explain a little further about the replacement leads?
Thanks,
Pete
"johnf" <john_f@bigpond.net.a> wrote in message
news:%23ZyksI$JFHA.2132@TK2MSFTNGP14.phx.gbl...
> johnf
>> Ron,
>> Pete
>>> Hey Pete,
>>> Click on
>>> Action
>>> use
>>> the CD
>>> your drivers> If
>>> recording
>>> windows to
>>> prefer to
>>> click
>>> but after that
>>> looking for
>>> Ron J
>>>> would I
>>>> check?
>>>> properly.
>>>> Pete
>>>> > are
>>>> > the
>>>> > Ron J
>>>> >> seconds than
>>>> >> nothing there
>>>> >> all with
>>>> >> the same results.
>>>> >> no help.
>>>> >> P.
Well, replace the 40 or 80 lead you're currently using - (it's easy to see
the difference between a 40 & an 80 = same width but more wiires) but FIRST
make sure the original is fully plugged in B4 you do that (test to see if
that rectifies the problem - (reboot)
If that doesn't help, borrrow & replace all flat cables to the drive -
possibly a faulty cable which I doubt, it's callled a 'sequentuel process
of elimination'
Next step if that fails is to borrow any oll CD drive, try that & let's know
what happens then
johnf
> (I'm not too technically orientated),
> Thanks,
> Pete
>> or borrow a couple of replacement leads, the let XP find the drive
>> again.
>> johnf
>>> Ron,
>>> recognize anything in the CD player.
>>> Pete
>>>> Hey Pete,
>>>> Click on
>>>> Action
>>>> etc, I use
>>>> the CD
>>>> your drivers> If
>>>> recording
>>>> windows to
>>>> chose the best speed for your drive > tip: fastest is not always
>>>> apply> click
>>>> but after that
>>>> looking for
>>>> Ron J
>>>>> would I
>>>>> check?
>>>>> properly.
>>>>> Pete
>>>>> > are
>>>>> > the
>>>>> > Ron J
>>>>> >> seconds than
>>>>> >> nothing there
>>>>> >> all with
>>>>> >> the same results.
>>>>> >> no help.
>>>>> >> P.
Thank you.
I will give this a try and report the results.
Pete
news:eHKbkoEKFHA.1340@TK2MSFTNGP10.phx.gbl...
> FIRST make sure the original is fully plugged in B4 you do that (test to
> see if that rectifies the problem - (reboot)
> of elimination'
> know what happens then
> johnf
>> Thanks,
>> Pete
>>> again.
>>> johnf
>>>> Ron,
>>>> Pete
>>>>> Hey Pete,
>>>>> Click on
>>>>> Action
>>>>> etc, I use
>>>>> the CD
>>>>> your drivers> If
>>>>> recording
>>>>> windows to
>>>>> apply> click
>>>>> but after that
>>>>> looking for
>>>>> Ron J
>>>>>> would I
>>>>>> check?
>>>>>> properly.
>>>>>> Pete
>>>>>> > are
>>>>>> > the
>>>>>> > Ron J
>>>>>> >> seconds than
>>>>>> >> nothing there
>>>>>> >> all with
>>>>>> >> the same results.
>>>>>> >> no help.
>>>>>> >> P.
