CD-Rom Drive is not working
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My Computer is not seeing my CD-Rom and when I got to the Properties for the
CD-Rom it says
"Windows cannot load the device driver for this hardware. The driver may be
currupted or missing. (Code 39)"
I downloaded all patches for windows and for the CD-Rom and still is not
working.
I even got a new CD-Rom and still same thing.
Anything would help.
Thanks alot!
The old Code39 caper. Mr. Nice check here
http://www.kellys-korner-xp.com/xp_abc.htm Select C and scroll to
CD-ROM Access Is Missing and Messages Error Code 31, Code 32, Code 19,
or Code 39 After You Remove Easy CD Creator :
http://support.microsoft.com/default.aspx?scid=kb;;Q314060
NOTE : If you are getting a code 39 message, it may be that additional
third-party filter drivers were added to UpperFilters and LowerFilters
values in addition to Adaptec filter drivers. In that case, you may try to
remove the non-Adaptec filter drivers first, leaving the Easy Creator
filters in place to see if the Code 39 goes away. If you still receive an
error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters
values completely in the preceding key.
"Mr.NiceGuy" <Mr.NiceGuy@discussions.microsoft.com> wrote in message
news:9C380F4A-C704-462D-8761-6465F4CE3DA0@microsoft.com...
> the
> CD-Rom it says
> be
> working.
> Thanks alot!
None of the Links you gave work...
And im not a Computer wize so i dont really understand about the Filters so
if you could, could you give me instuctions on how to remove these filters.
Thanks
> > the
> > CD-Rom it says
> > be
> > working.
> > Thanks alot!
None of the Links you left semm to be working...
And I have no idea on how to remove the filters of witch you are talking
about...
Go to Start>Run type: regedit click Ok. When regedit opens
navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane you will see a value Upper Filters and Lower Filters.
Rt click on each one and choose delete.
That should do it.
See if this link works
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
"Mr.NiceGuy" <MrNiceGuy@discussions.microsoft.com> wrote in message
news:FD78C4DD-4F6B-4B33-BE3F-210AE02D9BED@microsoft.com...
> about...
>> to
>> 19,
>> to
>> Lowerfilters
Thanks alot!
Everything works great now.
Thanks again.
> navigate to
> That should do it.
> > about...
> >> to
> >> 19,
> >> to
> >> Lowerfilters
> CD-Rom it says
> working.
> Thanks alot!
