Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi...
I tryed Chaintech tech but all I get is a recording.
I thought I may try here before returning the board.
I bought the CT-SKT600 with new case, CPU (AMD 1800), 256 Kingston memory
and new harddrive.
The problem is that when I turn it on, the CPU fan spins for about 2
secounds then the board shuts down.
I took all the hardware (Video Card, Hardrive etc..) from the board and
attempted to power it up and it does the same thing.
I subsituted a known good CPU (AMD 1800 again..), new memory, and a new
power supply and it still only stays on for a few secounds.
I was reading the manual and there are two other fan (3 pin) locations for
case fan and system fan.
There is no connections for them on the case.
The board appears to be shutting itself down for some reason and I have
tryed everything I know.
The power light does stay on in the case as if it is getting power.
But the CPU fan and board shuts down.
Bad board??
Any suggestions or help would be appreciated.
Thanks in advance..
Joe
Hi...
and new harddrive.
Bad board??
Thanks in advance..
Joe
