Question Changing cpu ram slot1 not using
Sep 4, 2022
4
MOBO: Asus A68HM-K
CPU: AMD x4 760k
GPU: gt530
RAM: 4GB DDR (x2) , 8gb total
my new cpu x4 760k is not using ram slot 1 , when i try to put again the old cpu which is a6-7400k ram slot 1 is working , i try re seating the ram, and software setting still not work,
what is the possible cause of this? is cpu is broken ?
Cpu is bad. The memory controller or its contact with the pins is bunk. Most often happens when users install a cpu cooler wrong and tighten the upper right corner screw before seating all 4x screws and then force the cpu cooler down to get the lower left screw started.
how to fix that issue? i reseat the cpu and the cooler still doesnt read the ram try changing old cpu ram slot working
