Can i render without Video Card? for $700-$800... video cards are expensive. Thanks!
https://pcpartpicker.com/list/rNXPNP
Not with an "F" CPU. It has no integrated GPU, so you won't be able to install an OS or start programs easily. You will have to have some low end graphics card as a minimum.Can i render without Video Card? for $800... video cards are expensive. Thanks!
thanks for the info! Can i render on CPU(8..12-Core) with integrated GPU, without external video card?Not with an "F" CPU. It has no integrated GPU, so you won't be able to install an OS or start programs easily. You will have to have some low end graphics card as a minimum.
Can it? Yes.thanks for the info! Can i render on CPU(8..12-Core) with integrated GPU, without external video card?
