What's the cheapest method to get if the motherboard don't have any? So far only solution was though a HDMI converter. (~$20.) cuz I couldn't find any sound card or like Motherboard audio to SPDIF converter.
Asus Xonar Se - doesn't work for you?I couldn't find any sound card or like Motherboard audio to SPDIF converter.
Thanks. Good option. But still costs around $50. Maybe I'll try finding a used one.Asus Xonar Se - doesn't work for you?
Xonar SE|Sound Cards|ASUS Global
Xonar AE is a PCIe gaming sound card built with high-quality components to satisfy gamers who demand exceptional sound for the best gaming and multimedia experiences. Xonar AE delivers 7.1-channel, 192kHz/24-bit Hi-Res audio output with a high 110dB signal-to-noise ratio (SNR), and comes with a...www.asus.com
your mainboard has spdif output, but purchasing bracket with ports would cost about 20 bucks
Wow. Didn't know that. This is exactly what I need. Thanks.your mainboard has spdif output, but purchasing bracket with ports would cost about 20 bucks
https://www.amazon.com/SPDIF-Optical-Plate-Bracket-Gigabyte/dp/B07FJMD7BF
