Thanks Lutfij, nice to see you back again as well mate
Ok, in some semblence of order,
the core temps were stable throughout Ibt apart from the mentioned spikes so I know that is the solid temp as it quickly returns to 'normal'
Loop order at the moment,
Respump in case>Gpu1>Gpu2>Chiller>Radbox360>Radbox 360>Radbox pump>Cpu>Rx240 on roof>T-Virus1>TVirus2>Return to respump in case
The rads are doing the work of removing heat, the purpose of the chiller is just to provide cooler water for the loop, it is not intended to actively remove the generated heat in any way, thats the job of the rads/fans
I wouldn't have the Tec plate in the water as its aluminium, I may do something like that if I can find a suitable Cu plate
and no, I can't directly monitor the Chiler temps atm, I'm still waiting on the temp sensor for it to arrive, I'm currently going off an ambient sensor and the sensor in one of the T-Virus reservoirs,
maybe the dedicated sensor will show something up, but normally a loop isn't more than 1-2'c difference anywhere in the loop
Thanks for the interest and I hope we can get some better results soon
Ryans thread btw, not a sad ending, just a confirmation of one method not working,(well not without a lot of balancing), its by trying things that we rule out less effective ways of accomplishing a goal, so its never the end, only a lesson and a new beginning
**Ryan posted as I was writing this
@Lutfij, glad you're liking it mate
Moto
