Question Choosing a 75hz or 144hz monitor.
Jul 27, 2019
Hello, I would like some advice when choosing a monitor which has 75hz or another one with 144hz.
My specs are:
16gb of Ram
AMD Radeon R9 390
Ryzen 7 1700
MSI X370 Gaming Pro
The main use would be for gaming at 1920x1080 on FPS mostly, and on secondary for editing and programming(but I believe this last one might not influence much when choosing).
I also would like to know if the FreeSync feature is worth looking for when choosing with these features and what recommendations are best.
My budget is up to 400 USD.
I would go for 144hz freesync. Freesync is fairly cheap and 144hz is 100% worth it for the smoothness especially when you're playing fast paced games like fps. I must warn you though, once you game on 144hz, you'll never go back to 60hz. Hope this helps man
Reactions: AlaskaInSight
If your video card and CPU are not giving you 144 fps or more in the games you play, using a 144 Hz monitor is just a waste of money.
Read this to understand why that is true:
