Question Chrysler 200 Wont stay running
alexanderwe6
42
I recently purchased a 2013 Chrysler 200, after a few days of owning the car, the car would start, the red safety light in the dash would turn on, and the car would turn itself back off. I had the keys reprogrammed, and that fixed it for a few starts. We had the car hooked to a computer, and they sai the ambient air temperature sensor was bad, we replaced it, and it is still having the issue.
Did you get the code of the error or get it read again to see what the error means. Often the code won't give you a specific part. Rather it gives you a starting point. Replacing the most likely cause and working your way back. The ambient air temperature sensor was probably the most common fix.
kaehligj
335
28
695
58
It wont help you just replacing out of the box any component detected bad in a car diagnosis.
You need a proper problem tracing to find the source of the problem.
