W wcrockett Reputable Feb 26, 2016 54 2 4,535 Aug 19, 2019 #1 Hi all, I need to clear the CMOS on an old Lenovo 3000 N100 laptop. It has no jumper pins, and the CMOS battery is soldered to the board, it does not post. Can I clear the CMOS by shorting the battery, or do you recommend another way? Thanks.
NightHawkRMX Titan Ambassador Jan 1, 2018 18,589 3,985 81,540 Aug 19, 2019 #2 Is there a reset button? I wouldnt suggest shorting a lithium battery. Upvote 0 Downvote
W wcrockett Reputable Feb 26, 2016 54 2 4,535 Aug 19, 2019 #3 remixislandmusic said: Is there a reset button? I wouldnt suggest shorting a lithium battery. Click to expand... Nope, no reset button of any kind. Shorting the battery would work then? Upvote 0 Downvote
