Hello all,
Wanted to ask a question concerning a problem I have...
So I got my Cooler Master CM690 II Advanced, and it's got a front 120mm fan in the front... I decided one day to put it in a different location on my case and (noobishly), I didn't take note of which wire was for the power and which goes to the LED on/off button on the case.
Since I don't have much experience with fans and stuff, I plugged the fan power cable into the LED button port and the fan LED into the power port (Note: They were not labeled). Now my button on my case is dead, it had smoke coming outta it! And it doesn't get actuated anymore. I did also notice that the wire was fairly hot when I disconnected it, maybe it got shorted out or something.
In conclusion: The LED of the fan doesn't work no more, but the fan itself runs perfectly fine...
And so my question is: Is there anything I can do to get it working again? Or to hook it up directly?
Thanks in advance! 😀
