Cmos battery + plastic casing ripped off. How to fix?
Jan 1, 2019
Hello, I have a P9X79 LE motherboard and I have been trying to change BIOS settings but it doesn't work. I checked the cmos battery and... there is none. Even the plastic that holds the battery has been ripped off, leaving two pins sticking out.
Now I was wondering how you would fix this? Can I buy a laptop cmos battery, strip the wires, then solder them to the pins? Or should I just give up?
Jan 1, 2019
I don't know how to upload a picture here. It is asking for a URL.
maybe this works.
(http://tinypic.com/r/23sgapu/9)
vincentneo
Proper
Dec 25, 2018
56
9
Jan 1, 2019
Hey thanks that might work. Yeah that was the right photo. Yea I have a soldering kit. All I would need to find out is which pins/wires are + and -. Also, does it matter if I get some solder tin on the motherboard? As long as it doesn't touch any other conducting parts it should be fine right?
vincentneo
Proper
Dec 25, 2018
56
9
Yes, you will have to find the + and -. Soldering definitely requires solder, so you do have to get some on the motherboard. Just be mindful to not bridge (touch) anything with the contacts. You wouldn't want a short circuit. Afterwards, it should be fine.
Wish you luck! Any questions do ask, I'll try to help.
Similar threads
