Coaxial to Ethernet adapter to router to PC, does it work?
Mar 18, 2018
I want a connect from my Coaxial port to my PC
There is a router in another room and I cannot use 2 routers that utilise a coaxial port
Can I use a coaxial adapter to ethernet to router (uses ethernet) to PC?
Wall--Coaxial Adapter to Ethernet--Router--PC
Or do I have to use a MoCA adapter?
If I do have to use a MoCA adapter, is there any cheap and good brands that I should be looking out for?
Thanks in advance.
USAFRet
Router->ethernet cable->MOCA->house coax->MOCA->ethernet->PC
This will probably work:
https://www.amazon.com/Actiontec-Bonded-Ethernet-Adapter-ECB6200K02/dp/B013J7O3X0
Similar threads
