I'm using an Acer H233H (23", 1080p) and I've noticed that colors often seem to 'bleed' to the right of where they should be on the screen, almost like a faint double image that is displaced slightly to the right.
I've never owned an LCD besides built-in laptop screens before, so I'm not sure if this is simple a viewing angle thing, a hardware issue or a configuration issue. I haven't installed any custom color profiles or tweaked any settings for this display in particular; aside from setting the resolution I've let Windows 7 and the screen's auto config function handle settings.
So, I guess I have two questions:
1. What's causing the colors to bleed to the right and how can I avoid it, if at all?
2. What else should I do configuration-wise to improve image quality? Aside from the bleeding nothing looks "wrong" but that doesn't mean everything is optimal. I've heard it's good to get a color profile file from the display manufacturer to replace Windows' default color profile to match the hardware more precisely. Should I do that? Can someone point me to an FAQ (I'm not tech illiterate, just Windows and LCD illiterate; I assume this would entail downloading a file from Acer and then replacing a file in some system directory?)?
Thanks in advance.
Thanks in advance.
