Question Combining y cable and pwm extention to hub - Safe?
Iamsotired
42
I got a Fractal Design - Define 7 XL. In it there's a Nexus+ 2 Fan Hub. It supports 3x 4-pin PWM.
Problem is I got 4x PWM fans (Noctua NF-A14) 140mm
3x Front Intake
1x Exhaust
I intend to have the exhaust plugged in the hub. Leaving 2x PWM left on the hub.
So I was thinking plugging 2 front fans with y cable (Noctua - NA-YC1) then to a pwm extention cable then the hub. Is that okay?
The 3rd front fan will plugged with an pwm extention to the hub.
Hello
I checked. The manual (1-17) says each header
CHA_FAN1 - Max. Current 1A. Max. Power 12W
CHA_FAN2 - Max. Current 1A. Max. Power 12W
The Noctua NF-A14:
Input Power: 1.56W
Operating Voltage: 12V
And we got 4 of those.
So you think it's okay?
oh 1amp yeah it will be fine with 2x fans on one with a Splitter
Reactions: Iamsotired
