To all with the Presario R3000. The problem is the lousey soldering job the Chinese did when they attached the power unit onto the motherboard. I fixed my problem for $9.00.. You need a good soldering iron and have to do some minor cutting underneath the plate above the keyboard to the right. There, you will see the solder points that need to be re-soldered. I fixed my computer 1 1/2 years ago and it works great. Yes, as some mentioned on this post, you can by-pass this by using the all-in-one media plug to the right side of the laptop. But $9.00 is alot less expensive then the $$$ I'm reading these plugs cost.
Compaq/HP know of this problem.. Yet, they have refused to fix as this would have been a tremendous expense for them.....
