Hi,
The PC is running on battery power only. I even have to play with the power cord to get it to charge. Occasionally, for about 10 minutes, it will run on AC power, but that's it.
If he soldered it, he may have pushed the positive pin not far enough through the hole in the board to get a firm solderpoint, and it broke off again. Could be the pin is too short because he used the old broken one, outcome is the same. There might be an issue with dying capacitors on the board, leading to a too low amperage to charge the battery proper, or run the machine straight from AC. Some fiddling with the jack turns the power on/off for a couple of times, just may lead to a temporary success. (Hence the 10 minute success)
From a topic about erratic charging:
""Further Update - Fault repaired! After lengthy and tedious investigations the erratic behaviour of the battery charging/failure to run from the DC jack has been nailed. My motherboard uses MAXIM/DALLAS integrated circuits for power management and I gleaned a lot of useful info from application sheets provided on the web. Whilst the problem initially seemed to be related to the DC jack itself i.e. plugging the charger in and out would sometimes initiate charging, sometimes not the actual fault(s?) were traced to defective decoupling capacitors on the motherboard. There were at least 5 or 6 of them marked as NE* AA8 - they are 100mfd NEOCAPACITORS - conductive polymer tantalum capacitors - three had developed very high electrical leakage rendering the power control circuits unstable and eventually inoperative. The asterisk in the part mark is the production date code, in my case they were 's'. Changing these capacitors is NOT a job for the dabbler - you need to be VERY good at soldering and these parts are easily damaged by excessive heat. ""
There are actually 7 of these capacitors on the board. They cost next to nothing (20 cents a piece), but soldering them is difficult, because of 1mm large adjacent resistors, that just float away when getting to hot. A neighbour with better eyes and soldering skills/tools than I have did the job for me, to no avail, that's when I found one resistor sitting on top of a nearby solder point of a replaced capacitor.
So I bought a board off ebay for $240 incl. shipping, it showed no video, returned it, and now it is lost (I think) for 2 weeks in the us mail system. Seller did not seem to keen on giving any service but would investigate (why do these sellers always present themselves as plural when it comes to some conflict, "we have pulled it from a working system", "we will carefully investigate", to look more impressive in knowledge because we are 2 at least, or a company?)
In short, payed about $300 (board, taxes, postage back) and still empty handed, you are not alone in your struggle!
