My R3240US got the the point that it would charge the battery if left off with the cord jiggled just so to turn the front lightening bolt orange for an hour, or run the PC on battery if powered up, but the short in the power cord was too tenuous to run the PC on AC in, no matter how I tried and tried to adjust the cord.
I'm sharing my quote posted recently at takeitapartDOTnet, followed by my 25 minute fix at the end.
Having had some experience and background in such actions (class action and other legal maneuvers) I wouldn't hold my breath. Unless someone can demonstrate an implied usability beyond the warranty period, my hunch is we are chasing a losing cause. This is called Caveat Emptor - Buyer Beware. From all the posts it appears that HP/Compaq upheld its warranties during the limited warranty period. I recall that this laptop was initially a bargain at less than $900 which compares to over $2,000 for the last X-series Thinkpad I purchased over three years ago, but is still going strong. To make the automobile analogy, we bought Yugos where others bought Buicks. That was a risk we were willing to take at the time of our purchases, and probably must accept now. That said, I am not a satisfied consumer and I can guarantee that I will not be purchasing another HP/Compaq laptop in the near future, nor will I be recommending them.
Right now my NEW battery is charging up just barely on the laptop. When it is done, I will be backing up the entire PC and then taking apart the old battery and direct wiring it to a 110V AC to DC transformer. I'm pretty sure this "tampering" will void any action I would otherwise have, but at least I will know definitively whether or not I can continue to run this PC or or not with the slight mod. If it doesn't work, I still can go back to the pictures at the top of this post and try to re-solder the power outlet.
The following link to a HP Limited Warranty might be good bedtime reading for some:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00019915&lc=en&cc=us&dlc=&product=86633
Good luck to those that take an alternate course., but remember that Time is Money! I'll keep you posted of my progress with the battery mod. Dead batteries are probably going for less than $10 plus shipping on e-bay.
Cheers!
Jeff
Following that post, I went against my own drethers and took it apart. I should have gone with the battery bypass or the media cord (which I only learned of today).
I found that if I flipped it on its back and took off the battery, the hard drive and the RAM cover off, that I could then take off the CPU cover plastic by uscrewing all the screws and leaving them in their sockets followed by lifting the black plastic cover straight up with the screws still in place, followed by unscrewing the CD/DVD locking screw (approx center of CD spindle within) and removing that screw alone, unsliding the DVD drive followed by unscrewing all the remaining screws in the remaining bottom black pastic, but leaving the screws in place and lifting it up gently enough to keep all the screw where they needed to be (like before), I got it apart in about 4 minutes. Then I took off the speaker assembly, and mini-sound card leaving their screws in the slots. I flipped it over and at that point pried the upper plastic gray cover off at the base of the screen, followed bt removing the 4 keyboard screws and the 4 now visible hinge screws, the wrap-around upper plastic could be removed from the mother board. Total time into it so far 8 minutes. ANother minute and the CPU was off, followed by its wrap-around gray chasis/sink.
I then noted the lack of solder near the power jack in question and the proximity to the HOT CPU. I pulled off the CPU cover and fan covers and extracted a TON of dust bunny. That was the apparent source of my overheating problem. It also probably weakened the minimal solder on the socket through.
I took the board to a TV repair shop and for $5 and in 5 minutes he resoldered the four pins nicely. I thought I was in the clear. I re-assembled it in 6 minutes and only had one screw extra. I plugged it in and the lightning bolt came on orange (good sign). I then turned on the power button and it glowed orange as did the mouse button and the fans whirred up. Still thinking good thoughts there. About 5 seconds later the fans stopped (no dust bunnies to fight) and the three orange lights remained lit, but nothing else happened. I expected to see the Compaq splash and never saw it. I killed it and listened and felt for the hard drive to spin up. Nothing. I tried several more times and was able to toggle the mouse control light, but no POST occurred.
Any ideas? At this point the lightning bolt stays fully lit so it looks like I solved one problem, but caused another. Clearly the Achillies Heel is the 2 cent power socket with a spot of solder where more would have been better. Any ideas would be much appreciated. As far a taking it apart and putting it back together goes, that was easy. On a scale of one to ten, I would give it a 4. I don't recall locking the CPU so that might be it. Anyone? If you have had luck getting a new motherboard, please share your source.
Oh, a note to those who have yet to have this problem, remove the CPU cover occassionally and clear the bunnies. This is the only laptop of 15 that I have owned that I ever found internal dust bunnies in.
Thanks in advance!
Jeff
