IMPORTANT NOTICE:
My case is a Corsair 600T White Edition, so, to avoid headaches (for me) Please post whether your sure if the equipment will fit.
So... In much much much much much much thought over the past few weeks, instead of getting a Rasa 240 Kit, I've decided just to build my own.... With 220(?)$ Worth of headroom. I want to buy during Black Friday and Cyber Monday to save $$$ for better parts. Before I pull the trigger on this though, I want some opinions from you wise peoples at Tom's Hardware.
I prefer to get a single loop system. For now, I just want to cool my CPU with headroom for a GPU cooling upgrade. (Will get more radiators for that purpose when the time comes)
Here are the parts that I might buy: (Subject to change)
Sorry for the massive amount of "Enters", just wanted everything to look neat.
Anyway, all my parts are subject to change, and I am open to new ideas.
Thanks!
My Specifications:Pump:
Swiftech MCP35X
Reservoir:
(?) No idea. Preferably one that will be able to fit my pump?
Radiator:
MCR220-XP Radiator OR a XSPC RS240
Waterblock (CPU):
Apogee XTL
Tubing:
Barbs and Fittings:
CPU:
Intel Core i5 2500k Processor
Graphics:
XFX 6850 1GB (Upgrade?)
Motherboard:
Asus P8Z68V-Pro
Power Supply:
Corsair HX750
Thanks!
