Hi all,
Firstly many thanks for all the wonderful threads. I've learned a lot by reading your thoughts.
Still I'm confused about something - I tried searching but couldn't find a specific answer.
I'm overclocking my lowly E2220 from default 2.4 ghz to 3 ghz. This was done on a Gigabyte 945P-S3 mobo.
I was able to get CPU to 3.4 ghz - a full 1 gig over normal spec - so I thought: horrah I'm lucky to have such a chip.
Note this is done using the stock hsf by intel and using speedfan and/or bios settings to keep temps reasonable - never got over 60 C at full load.
I'm using PC-6400 memory - DDR2 667.
I was able to get cpu to 3.4 ghz only if the dram frequency (from CPUZ) runs at 280 mhz or so.
I am also able to get cpu to 3 ghz with dram frequency of 333 mhz.
So here are my 2 basic questions. Am I better off to run cpu at 3 ghz to get better bandwidth and usage from memory or can I run it at 3.4 and have to drop dram frequency to 280.
My memory (according to SPD tab on CPUZ) can run at max frequency of 400 mhz.
But for the life of me I cannot get it to run at this frequency. I've tried changing mem timings, increase voltage to ram, even cpu, and different ratios in bios and all other combinations but still I cannot run it at 400 mhz and get a decent overclock from CPU.
What am I doing wrong? Please can you advise?
Many thanks in advance
hany
hany
