Question Connect Desktop Via Anydesk/Teamviewer without attaching Monitor
arpitsoni90s
48
I am trying to connect to my computer using anydesk and teamviewer but I have not attached any monitor to it. Because of that reason anydesk or teamviewer only shows blank screen but as soon as I plug a cable and monitor then it will show me a screen.
But I want to use the computer without screen. I researched on internet and found out that I can use some dummy plugs and then anydesk or teamviewer will show me a screen but not sure how to do that.
Update your post to include full system hardware specs and OS information.
So you are trying to remotely connect to your computer from another location and work on your computer without the computer's monitor turned on and/or even connected - correct?
Regarding "dummy plugs" - provide the link(s) that you found.
Do you mean something like this product?
Display emulator
Display emulator
Yes I wanted headless display plug. Thank you
