Hey guys,
I recently upgraded to the Arctic LF3 AIO, and it's my first time having an AIO cooler. I'm running a TUF GAMING B550M-PLUS & Ryzen 5 3600.
I wasn't sure on what to use when setting up, so I went with the all in one connection, plugging it in the CPU_FAN header on the motherboard.
I'm not sure if I've made a mistake going down that route since I feel like the AIO not performing on the level that I'm expecting it to be - I've read countless reports of people saying the AIO is super loud beyond 50-70%, yet I'm at 100% and I barely notice it running at 1900 rpm.
Have I made a mistake here..? Should I try and swap out the all-in-one connector to the one that has the PUMP, VRM & FAN separately, and if so, where should they go?
I read a comment on another thread stating:
"One great way to avoid overloading the Amps on a header is to split up the load. If at all possible, depending on what headers your mobo has, the prefrerred arrangement would be one of these:
1. PUMP on CPU_FAN, RAD FANS on CPU_OPT
2. PUMP on AIO_PUMP, RAD FANS on CPU_FAN
3. PUMP on CPU_FAN, RAD FANS on SYS_FAN IF you can set that header to use the temp sensor in the CPU chip, and NOT the one on the mobo.
4. PUMP on a SYS_FAN / PUMP header that CAN be configured for PUMP operation which WILL feed it full power always, PLUS we hope it will take strong action IF the PUMP fails; RAD FANS on the CPU_FAN header."
Going off of option one, should I go:
PUMP -> CPU_FAN
FAN -> CPU_OPT
VRM -> CHA_FAN1 (located on the left of the CMOS battery)
I greatly appreciate your input on this since I'm really questioning if I did things right
I'm open for any questions you might have regarding my setup so you can better guide me forward.
Cheers 🍻
PUMP -> CPU_FAN
FAN -> CPU_OPT
Cheers 🍻
