Hello everyone, I'm trying to connect both a Wi-Fi router and PC to ISP's GPON Terminal(Huawei EchoLife HG8240). The problem is, when I connect just one cable through LAN port (For example from Terminal to the Wi-Fi router), then the connection is fine. As soon as I connect both cables to the GPON, there is no connection on both cables. I would like to run separate cables from the Terminal, rather than one cable to WI-Fi router, to which the PC is connected with another cable. Terminal has got 4 LAN ports.
