Hi there,
I'm sorry if this has been discussed before, but I can't seem to find a straight answer.
My question is: Can I connect an HDMI port monitor to a DVI-D Dual Link port PC with, e.g., an adapter that converts HDMI to DVI-D? Will it work?
My computer has HDMI and DVI-D Dual Link outputs (GTX 1650) and I want to buy two 16:10 monitors, preferably the same model. The problem is that most monitors don't have both HDMI and DVI-D ports. They usually have HDMI and VGA or HDMI and DisplayPort. I'm really eager on buying two Dell P2217 monitors but one of them I'd have to connect with an adapter (either HDMI to DVI-D or DisplayPort to DVI-D).
The reason why I'm doubting adapters is because I've tried connecting an existing VGA monitor with a VGA-HDMI adapter and it didn't go well - the screen appears all blurry.
Thanks all in advance!
