Hello, all. I am looking for suggestions on which way to go relative to setting up a NAS on a small network.
BACKGROUND:
We have our Internet router which provides all stations (4-8) with wi-fi and also connects to a 4-port switch via RJ-45. This switch provides connectivity to a particular large format printer for a couple of the stations only - It is needed. The internet in this area (and the provided hardware by the ISP), leaves a lot to be desired (Sagecom HomeHub 2000 for 25/10) and wi-fi speeds hover around the 15/2 area.
We have a few key folders that we need shared across our workstations and right now, we do this over the network as shared folders. Because these transfers go through our router, data transfer speeds (as well as internet speeds) slow down considerably. We often require R/W access to files of a few GBs from these shared folders, but the current set-up makes it almost unbearable.
TARGET SOLUTION:
We want to leverage a NAS, preferably 4Bays, and 4 SSDs, on an entirely internet-free network. The plan is:
3. have 2 bays x 256GB SSDs containing data and 2 bays x 256GB SSDs backing up the ones containing data (SSDs are Samsung 860 EVO)
REQUEST:
The current set-up sees 2 stations connecting to a switch that enables them to print to a large format printer, also connected to said switch via RJ45. While the current station's NICs are Gigabit, the printer's Ethernet connection is 10/100. Because of this, I want to segregate the printer from the NAS, so as to not bring Gigabit devices down to 100mbs.
BACKGROUND:
TARGET SOLUTION:
- connect the NAS to an 8-port switch
- install Gigabit NICs in all workstations
REQUEST:
- What would be the best NAS for this?
- Can a 4bay NAS be split like this (drives 1 & 2 data, drives 3 & 4 backing up drives 1 & 2)? Is that RAID 10?
- Can the switch alone be used or do we have to go through a router?
- Can a separate router from the one currently used for the internet be used?
- Do you have any suggestions for this switch and/or router?
