Question Constant audio glitches ?
DJ_Pichu
11
Hello, recently my PC has been doing constant audio glitches. I installed LatencyMon to check for what exactly happens (providing details below). What step should I take to solve the problem? Thank you
Link to Main Image: https://ibb.co/kMpPqg1
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One
or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU
throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:43 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-1GQ8HNI
OS version: Windows 11, 10.0, version 2009, build: 22631 (x64)
Hardware: System Product Name, ASUS
BIOS: 2413
CPU: AuthenticAMD AMD Ryzen 5 7600 6-Core Processor
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 31968 MB total
CPU SPEED
Reported CPU speed (WMI): 3801 MHz
Reported CPU speed (registry): 3793 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS
setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine
started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in
response to that event.
Highest measured interrupt to process latency (µs): 15552.40
Average measured interrupt to process latency (µs): 8.658452
Highest measured interrupt to DPC latency (µs): 2482.40
Average measured interrupt to DPC latency (µs): 2.908929
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 833.365146
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.021181
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.023753
ISR count (execution time <250 µs): 119564
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 259
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has
finished execution.
Highest DPC routine execution time (µs): 2450.67440
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 556.12 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.022650
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.088306
DPC count (execution time <250 µs): 277904
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 102
DPC count (execution time 1000-2000 µs): 8
DPC count (execution time 2000-4000 µs): 2
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving
the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and
pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 645
Hard pagefault count of hardest hit process: 213
Number of processes hit: 28
PER CPU DATA
CPU 0 Interrupt cycle time (s): 5.522615
CPU 0 ISR highest execution time (µs): 833.365146
CPU 0 ISR total execution time (s): 0.464426
CPU 0 ISR count: 119732
CPU 0 DPC highest execution time (µs): 2450.67440
CPU 0 DPC total execution time (s): 1.623809
CPU 0 DPC count: 255942
CPU 1 Interrupt cycle time (s): 2.519438
CPU 1 ISR highest execution time (µs): 16.540469
CPU 1 ISR total execution time (s): 0.000675
CPU 1 ISR count: 91
CPU 1 DPC highest execution time (µs): 803.379910
CPU 1 DPC total execution time (s): 0.01880
CPU 1 DPC count: 3320
CPU 2 Interrupt cycle time (s): 1.714985
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 802.01740
CPU 2 DPC total execution time (s): 0.009386
CPU 2 DPC count: 2359
CPU 3 Interrupt cycle time (s): 1.747543
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 56.474031
CPU 3 DPC total execution time (s): 0.004331
CPU 3 DPC count: 1189
CPU 4 Interrupt cycle time (s): 1.959712
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 790.476140
CPU 4 DPC total execution time (s): 0.027293
CPU 4 DPC count: 5569
CPU 5 Interrupt cycle time (s): 2.055642
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 340.31690
CPU 5 DPC total execution time (s): 0.014451
CPU 5 DPC count: 3324
CPU 6 Interrupt cycle time (s): 1.634112
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 795.595571
CPU 6 DPC total execution time (s): 0.004014
CPU 6 DPC count: 793
CPU 7 Interrupt cycle time (s): 1.689672
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 40.704983
CPU 7 DPC total execution time (s): 0.003242
CPU 7 DPC count: 805
CPU 8 Interrupt cycle time (s): 1.961516
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 809.411020
CPU 8 DPC total execution time (s): 0.007530
CPU 8 DPC count: 1702
CPU 9 Interrupt cycle time (s): 2.007242
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 51.645136
CPU 9 DPC total execution time (s): 0.006556
CPU 9 DPC count: 1336
CPU 10 Interrupt cycle time (s): 2.124894
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 53.819141
CPU 10 DPC total execution time (s): 0.005091
CPU 10 DPC count: 951
CPU 11 Interrupt cycle time (s): 2.226893
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 71.561824
CPU 11 DPC total execution time (s): 0.004575
CPU 11 DPC count: 726
Apart from your OS version, the processor, the amount of ram, the maker of your motherboard and the BIOS version, there's not much about your system specs. Please list your specs like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Use DDU to remove all GPU drivers(intel, AMD and Nvidia) in Safe Mode from your platform, then manually reinstall with the latest driver sourced from Nvidia's support site in an elevated command.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
CPU: AMD Ryzen 5 7600 6-Core Processor
CPU cooler: Wraith Stealth Cooler
Motherboard: ASUS AMD PRIME B650-PLUS AM5/DDR5/2x M.2/2.5GbE ATX Motherboard
Ram: 32GB (2x16GB) Corsair Vengeance Black DDR5 PC5-41600 (5200MHz) Memory Kit
SSD/HDD: 1TB Crucial P3 M.2 2280 PCIe3.0 NVMe Solid State Drive
GPU: GTX 3060
PSU: 750W AeroCool Integrator 80+ Gold Full Modular ATX Power Supply w/ 120mm Fan
Chassis: Corsair 3000D Airflow Black Tempered Glass ATX/mATX/mITX Mid Tower PC Case w/2x120MM Fans (I retrieved it 3 months ago)
OS: Windows 11
Monitor: ASUS VE248H 24" Full HD 1920x1080 2ms HDMI DVI VGA Back-lit LED Monitor
Here is the list.
Is there a tutorial I could follow for using DDU removing all GPU drivers safely and reinstall them? Thank you
