I recently "fixed" my desktop, and when I first used it, I tried a pair of earphones to listen to some music. Sounded fine and everything, but once the song ended, I heard this low ringing sound (a high pitched, but low volume "eeee" sound). Anyways, this was a couple weeks ago, and I assumed it was simply my earphones, so I just used another pair. The new pair is much older, but it didn't receive the same sound, so my assumption seemed to hold. Unluckily for me, the left earphone of that set died, so I am using the previously mentioned earphones (the ones with the noise). It still has it, but I noticed it wasn't constant. Today, I just happened to drop my mouse from the edge of the desk, and I heard no more ringing. I put the mouse back, and I heard it again. Whenever the laser comes in contact with any solid surface, it makes that ringing noise.
What seems to be the problem? Is it my mouse, earphones, or sound card/mobo's fault?
By the way, I am using the front panel of my desktop to hook up the earphones.
Thanks for any info!
John
John
