[SOLVED] converter (hdmi to vga) affects quality?
mzsystem
22
i using simple hdmi to vga adaptor
does this adaptor affect quality, resolution, response time ,refresh rate or anything else?
my system specs:
rx 580
dell-p-P2212H
can using dvi-d help quality for gaming?
Any help would be much appreciated...
There would be a compromise in signal processing from digital to analogue. Quality, resolution/Hz would be affected but by how much, just wouldn't know.
Your monitor has DVI-D input which any Hdmi to DVI-D cable will work passively without requiring power to convert. Also no compromise in quality or response.
Reactions: mzsystem
Yes, it does, if the cable/converter is not good. And...
No, it doesn't, if the cable/converter is decent enough. My little brother PC use it, at first, it's torturing eyes. Changed the cable (it's thicker, also has better build quality) and there's no noticeable difference to using native HDMI cable.
Reactions: mzsystem
