R rmnsachy Apr 11, 2019 8 0 10 Apr 11, 2019 #1 so i'm looking for a new power supply and i'm sorta worried that if i get a psu that cant fun my gtx970 overclocked bit and the rest of the pc then what do i do, or will a 600w psu do it with no problem
COLGeek Cybernaut Moderator Apr 6, 2009 59,670 5,373 184,340 Apr 11, 2019 #2 Yes, a Cooler Master 600w PSU should be able to power the components you listed. No worries. That assumes the PSU is in good working order. Upvote 0 Downvote
R rmnsachy Apr 11, 2019 8 0 10 Apr 11, 2019 #3 COLGeek said: Yes, a Cooler Master 600w PSU should be able to power the components you listed. No worries. That assumes the PSU is in good working order. Click to expand... it gonna be shop bought brand new so it should be able to handle if i over clock the gpu and run everything else, correct? Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,670 5,373 184,340 Apr 11, 2019 #4 Yes, it should be fine. I would prefer a better quality PSU personally, but the CM PSU will suffice. Upvote 0 Downvote
