Cooler Master 840 ATCS Project
MonsterMawd
807
I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
I should know by first week of November what hardware CM will be sending me.
Conceptual drawing by E.E.L. Ambiense
Case Mods & Supplies used in this project by Mnpctech.com
Machined Aluminum Computer Case Feet Link
Acoustical Sound Proofing Sheets for your PC
Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
http://www.mnpctech.com/colored_acrylic_sheet_casemod_window.html
This is the Honeycomb Modders Mesh we used.
PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
http://www.mnpctech.com/Computer_Billet_Fan_Grills.html
http://www.mnpctech.com/Computer_Fan_Grills_Laser_PC_Fan_Grills.html
The canvas for this PC build is the Cooler Master 840 ATCS
Adding window to Cooler master 840 ATCS
Using tape roll to make curved corner
Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
Using a Jigsaw is much quicker than using a Dremel to cut your window
MonsterMawd
807
Thanks for comment! Once everything is assembled, all of the details like weathering, graphics, and effects can be airbrushed on the exterior like the concept drawing.
Left side panel, the hole will have burned effect airbrushed on later
Right side panel
Cooler Master sent over 3x 230mm red led fans, 1x for front intake, 2x top exhaust
The 840 normally comes with Black frame 230mm fans, no leds.
I like the flexible conduit. Never thought of using metal conduit. I got some "chrome" flexible plastic conduit at my local Fry's Electronics store for a case mod last year. Last night I was at Home Depot and spotted black flexible plastic conduit dirt cheap. Would be great for a case with an all black interior.
MonsterMawd
807
I agree, and have used it Johnny. I'm working on a HR GIGER biomechanical theme PC and used it on the bezel,
Here is the Prawn canister from the movie.
My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover.
Once it's painted and the window is darkened a bit, it should look eerie.
canister back cover
for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic with a heat gun, but more on that later!
http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html
MonsterMawd
807
I'm still looking for sponsorship of MB / CPU for that build.
I made the canister's window today. Using a heat gun to bend the Lexan.
Forming the arc in window by pressing heated piece on the Aluminum rod. It's HOT!
MonsterMawd
807
Thanks! The Prawn canister can't remain Silver. I prepped the aluminum surface with medium grit sandpaper, applied Black SEM self etching primer, then headed over to Brad's so he could apply the Pewter base color coat. Brad did all of the Prawn canister graphics by applying vinyl film and cutting the designs free hand with an Exacto, he used the movie still for reference. Look Ma, No vinyl film plotter or software!
Prawn canister window was tinted like original
Now THAT'S just skill and balls. A small mistake could have ruined a lot of work....
Anyways, thanks for the link, but there's only 4 or 5 grills for the 4x120 rads :cry: and non of them are exactly what I wanted. Looks like I gotta make on my self....
MonsterMawd
807
I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get.
MonsterMawd
807
pretty colors + rust = cool
There will be an MNU logo painted on this optical drive. Christopher likely traded something towards it, so he could view cd rom archived files from MNU perhaps?
More rust effects occur..
The new 600W Cooler Master Silent PRO didn't look right in a POS computer, it was treated to "rust lovin" as well.
MonsterMawd
807
District-9 is a dirty place. I would have a hard time imagining this looking pristine.
Intel Core 2 Duo 3.16 GHz Processor in Intel DX48BT2 Motherboard sent from Cooler Master.
I'm looking at this Cooler Master HYPER N620 and wondering ""What Christopher do differently with it?"
MonsterMawd
807
I wanted to direct the cooler air entering the front of the case to the cpu cooler. The 5.25 bay covers were removed to highlight the canister movie prop we made. It dawned on me that a fan duct could be mounted to a 120mm fan by modifying a 120mm round mesh fan grill. In the past, I would mold the fan duct into the front bezel with body filler, but this method is much easier and more versatile.
This method can be combined with 4.5" flexible tubing to isolate cool airflow. Imagine one end of the tube attached to a 120mm cooling fan in front of your case.
The 4.5" Flexible tubing can be found at Mcmaster, http://www.mcmaster.com/#duct-hose/=4zltce or you can "try" the "Heating & Cooling" department at hardware or home improvement stores like Home Depot or Lowes.
Supplies & Tools:
120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html
4.5" fan duct, http://www.mnpctech.com/FanDuct.html
4, #10 x 5/8" fan screws, http://www.mnpctech.com/thumbscrew.html">#10 x 5/8" fan screws</a>
120mm cooling fan.
Paint pen or pencil.
Tin snips.
Wire cutter.
Using a paint pen to trace the duct onto the round mesh grill.
a small wire cutter and Tin snips used to cut the 4.5" opening in the 120mm Modder's Mesh Round fan grill
You'll need to use the small wire cutter first, to make the initial cut before you can use the Tin Snips to cut the 4.5" hole.
Using Tin ship to cut the round mesh grill.
The result of you cutting should look like this.
120mm cooling fan. This fan has enclosed corners, you will need longer fan screws if you're mounting the fan onto something like a cpu cooler.
4, http://www.mnpctech.com/thumbscrew.html, #10 x 5/8" fan screws</a>
