Cooler Master 840 ATCS Project
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
MonsterMawd
807
I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
I should know by first week of November what hardware CM will be sending me.
Conceptual drawing by E.E.L. Ambiense
Case Mods & Supplies used in this project by Mnpctech.com
Machined Aluminum Computer Case Feet Link
Acoustical Sound Proofing Sheets for your PC
Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
http://www.mnpctech.com/colored_acrylic_sheet_casemod_window.html
This is the Honeycomb Modders Mesh we used.
PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
http://www.mnpctech.com/Computer_Billet_Fan_Grills.html
http://www.mnpctech.com/Computer_Fan_Grills_Laser_PC_Fan_Grills.html
The canvas for this PC build is the Cooler Master 840 ATCS
Adding window to Cooler master 840 ATCS
Using tape roll to make curved corner
Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
Using a Jigsaw is much quicker than using a Dremel to cut your window
MonsterMawd
807
Glad to hear guys are connecting through this log, thats what it's all about :)
Final photos, it's in Vegas for CES show now... Hopefully the Media mention it
Mitron Interlink Fan Controller was cannibalized and mounted in the rear of the chassis.
The prawn canister resides in the front 5.25 bays, under a single DVD drive.
MNU logo painted on the optical drive face. Did Christopher steal this to access archived files?
Flexible conduit seen through exploded hole in the right side panel.
The Prawn lettering was hand painted. You can download the font, http://www.district9movie.com/downloads/fontdownload.html
Rusted and scratches were hand painted on the exterior.
