Hi,
Today I installed the Cooler Master ML240L V2 for my Ryzen 5 3600, and I'm seeing some pretty high temperatures, I would have expected lower from a brand new AIO. Idle temps are from 38-47C, and load temps are up to 79C running Prime95. Do these temperatures seem appropriate for this cooler?
Just some extra info, the cooler is front mounted in an NZXT H510 with the tubes toward the top of the case. The fans are inside the case, in a pull configuration. The CPU isn't overclocked and is running factory settings. AIO_PUMP is running at 100% in BIOS.
Any help would be greatly appreciated!
Thanks
Thanks
