I currently have a Cooler Master Pro 5 RGB case and have had it for a while now, I am looking to upgrade my CPU as it is an AMD fx 8350 and I plan on upgrading to a Ryzen 7 2700x, but with that upgrade, I am getting an Asus Prime X470-Pro ATX Motherboard with Aura Sync. I am also getting Trident Z RGB ram but I have read that it is compatible but as far as my case I do not know if it is compatible with Aura Sync, I am getting a water cooled CPU fan from cooler master the MasterLiquid ML120L RGB, because its all the space I have so 120mm has to do and that is compatible so I think the front fans should be as well but I wanted to check here before I buy anything.
