Hello,
I am thinking of modifying the current cooling of my kit and would like to hear your opinions / suggestions.
Currently I have a Phanteks Eclipse P600S case with standard fans supplied with it installed on the front (intake) 3x140mm (phanteks), 3x120 Corsair LL120 RGB on top (outtake) and 1x140 Corsair LL140 RGB on the back (outtake). The CPU is cooled by be quiet! dark rock pro 4. I am going to replace the CPU cooler with be quiet! SILENT LOOP 2 360mm and now the question arises, what to do with the other fans:
- leave the stock phanteks ones in front,
- convert them to Corsair LL120 RGB,
- or get rid of these Corsair ones completely and replace them with something from be quiet!?
and if so: change them to 120 or 140 mm?
Thank you in advance for any insights, comments and suggestions.
Kind regards
Kind regards
