What I meant is that I expect Arrow Lake will face a thermal bottleneck/hotspot problem limiting its clock speeds. That, in turn, will constrain it to run at lower power levels that are more efficient. The main reason Raptor Lake gets into trouble with efficiency is that it's allowed to clock too high. Power usage scales nonlinearly with frequency, so it ends up running very inefficiently. If they had capped it a lower power limits, it wouldn't have such a bad reputation.
It's not the same as Pentium 4, because Intel clearly understands they can't keep scaling frequency and that's why they focused so much on IPC improvements in both Lion Cove and Skymont.
I think thermal density is becoming a more pressing problem than gate density. It's an easier problem for GPUs, because they can always increase performance by adding more ALUs. CPUs have a thorny problem that IPC increases are very costly in terms of gates.
IMO the problem is kind of the longevity side, as the wires goes ever thinner, electron migration becomes more of an issue, and of course, thermal density will likely be hit first.
Why would I care about how other people are using their PC's? That doesn't make sense. Most people might be running their T30 fans at 100% rpm, does that mean I shouldn't buy them? You are not making sense
It is because your claim about the efficiency is complete nonsense, here, in a forum, we are discussing the GENERAL bloody product, which is, what specified by the vendor, not how some random individual will use it in some weird way, nobody should care about how you use your PC, that's why in discussion, or reviews, should be based on the vendor designed spec, nothing more, nothing less, discuss the stock product pros and cons is fair discussion, when factual data is given, how you decide to use/purchase is at your decision. And you derail the thread once again for your liking of stuffs which means nothing to everyone else
e.g. it doesn't matter Bulldozer is a crap gen of CPU, it doesn't contradict that Ivybridge is a much better CPU than Bulldozer, but if one have a usecase or even the FX badge makes him feels better, or just he got the money for that, it is completely fine, but if someone claims POV-Ray test FX8350 is faster than i7-3770k, so FX8350 is a faster CPU, than it is BS in general.
That's using XMP, xmp is slow.
XMP is something kind of factory guaranteed to work, at least most of the time if you are not with very bad luck or get the crazy high freq kit for the top 1% IMC, other "tuning" (AKA overclocking) is something varies greatly from one over another, and it is beyond stupid to compare for example, a stock 7800X3D to a cherry picked 14900K with cherry picked Ram kit and tune it very carefully and maybe get faster and say 14900k is faster in gaming (which have no proof to even be true).
